if you recoat
Posted by Charlie Jones on Jul 30, 2005
while the epoxy is still "green" you don't need to sand at all. By green I mean somewhat soft to the touch, but just past the sticky part. I NEVER touch epoxy with sandpaper till I've gotten all the fill coats rolled on.
Once you get all those on, then 120 should be fine to start with, depending on whether you're gonna paint or go bright. If bright, then follow the 120 with finer and finer, up to and including at least 320
In Response to: Earliest Sanding Time? by raul calzadilla on Jul 30, 2005
- Thank you Charlie by raul calzadilla on Jul 30, 2005
Re: Thank you Charlie by Steve Miller on Jul 30, 2005
- Re: Rag on 4th coat ? by raul calzadilla on Aug 1, 2005
- probably not by Charlie Jones on Aug 1, 2005
- Re: Rag on 4th coat ? by RogerJ on Aug 2, 2005
