Re: ches 17 and leaky hat
Posted by Jim Stalnaker on Jul 29, 2005
Hi, I just read your message about leaky hatches and I thought I'd share a trick that I've used for model airplanes. When the wing is mated to the wing saddle, there often is some variation between the surfaces. To close the gaps, silicone gaskets are the easy way to go. Put a thick bead of silicone down and then put plastic wrap (from the kitchen) over it and then put the wing (hatch) in place and let it set up. After it is set up, the wing (hatch) can be lifted, the plastic wrap discarded and the resulting gasket should be a perfect fit. Hopefully, this would work for a kayak hatch, also. I've been contemplating using this on mine, but as of yet, I haven't tried it. Good luck, Jim
In Response to: ches 17 and leaky hatches by Ray on Jul 29, 2005
- Re: ches 17 and leaky hat by david on Jul 29, 2005
Re: ches 17 and leaky hat by Kurt Maurer on Jul 29, 2005
- Re: ches 17 and leaky hat by Ray on Jul 30, 2005
- Re: ches 17 and leaky hat by Moe on Jul 30, 2005
- asking for solutions by LeeG on Jul 30, 2005
- Re: Fastek buckles by LeeG on Jul 30, 2005
- perfection by LeeG on Jul 30, 2005
- Re: perfection by Moe on Jul 30, 2005
- survival vs function time by LeeG on Jul 30, 2005
- by on
- by on
- by on
- by on
- by on
- by on
- by on
- by on
- by on
