Re: Big Problem need advi
Posted by Moe on Jul 29, 2005
yes i've been paddling it's a chessapeak. the seams are aksessebal it's protected by four coats of epoxy no more. the crack in the seam is on the outside.
the materials are all top notch (west system epoxy with microfiber and okume plywood) the only weak point i can spott is the nails.
In Response to: Re: Big Problem need advi by Doug Judd on Jul 29, 2005
