Re: structural problem?
Posted by bubbacrawfish on Jul 27, 2005
If the problem is on the outside; it should be resolved when you fiberglass it. If it is on the inside the you should use squeeze some epoxy in there. The excess epoxy can be removed by sanding lightly after it dries.
In Response to: structural problem? by flip on Jul 27, 2005
