Re: Epoxy underside of de
Posted by CLC on Jul 27, 2005
As you note there is little or no wear on the underside of the deck. As a practical matter, if you let that coat of epoxy on the underside of the deck cure in order to put a second coat on, the deck will be too stiff to install on most of the kayaks. Thus, you should roll on one coat of epoxy and install the deck before that coat has cured.
Just make sure that the single coat is on the thick side, and don't leave any "holidays" (dry spots). Water will find a way to get in there.
In Response to: Epoxy underside of deck by paul on Jul 27, 2005
