using paddle
Posted by LeeG on Jul 26, 2005
this technique get's missapplied a LOT. The problem with it is that you're supposed to use the paddle to provide a reference direction for leaning a little,,the paddle simply tells you that you aren't falling the other way. Paddles were never meant to be bridges unless you get a heavy duty one piece shaft to handle the stress.
In Response to: Re: Duct tape saves the d by Peter on Jul 26, 2005
