Re: Sanding, How much?
Posted by Mislav on Jul 25, 2005
If you're careful in applying epoxy you won't have much sanding to do. Careful means:
1. apply epoxy with a roller and/or squegee
2. scrape all runs and high spots while epoxy is green (biggest sanding saver)
3. occasionally lightly sand inbetween epoxy coats (hand sanding will do, but expect at least 1 bigger session with a ROS to kill the weave pattern)
4. optionally apply last epoxy coats with a rag (as per Kurt's advice)
Following these guidelines left me with no more than 2 hours final epoxy sanding (mostly by hand).
In Response to: Sanding, How much? by John on Jul 25, 2005
