Re: modified sailrig deck
Posted by don on Jul 25, 2005
My thought was to plane down the shears to just a slight angle (through test fitting) and adding shear clamps (right term? or is it cleats?) to either side of the bulkheads (fore and aft) that would have a SLIGHT radius. If minimal enough, I'm proposing, than the deck should attach relatively easily, have the support of the cleats and look that much better...
I'm torn, as this is my first project and I am reluctant to 'throw out the rule book / directions' until I have completed a project.
Just seems like an easy change with good aesthetic payoff...
I'll keep you all posted on which way I go with it and the outcome...
Thanks fo your input,
Don
In Response to: Re: modified sailrig deck by LeeG on Jul 23, 2005
- Re: modified sailrig deck by LeeG on Jul 25, 2005
Re: modified sailrig deck by don on Jul 26, 2005
- Re: modified sailrig deck by CLC on Jul 26, 2005
- Re: modified sailrig deck by Brently Gill on Jul 26, 2005
- Re: modified sailrig deck by don on Jul 27, 2005
