Sanding, How much?
Posted by John on Jul 25, 2005
How much sanding is really necessary? It sounds like most of you spend as much time sanding as you did building. Is it really necessary to sand that much or can you sand off the high spots and rough areas and go for the varnish.
In Response to: Construction Haiku #17 by Monterey Matt on Jul 24, 2005
- Re: Sanding, How much? by Mislav on Jul 25, 2005
Re: Sanding, How much? by John on Jul 25, 2005
- Re: Sanding, How much? by Ed on Jul 26, 2005
