Re: modified sailrig deck
Posted by CLC on Jul 22, 2005
Since you have to work around the protruding, structural bulkheads, inducing camber into the SailRig MKII's ama decks will be tricky. Even a small amount of camber (24" radius or more) will give you the intended effect, but I can't help wondering if it's more trouble than it's worth.
In Response to: modified sailrig deck by don on Jul 22, 2005
