Re: deck installation
Posted by Steve Miller on Jul 21, 2005
Do a dry run with the straps. You will find there is a sort of sequence that needs to happen to get the deck tight with all the straps on. Also that may be a bit too much overhang as the straps pull the deck down the center may crown up. A helper is still a good idea.
In Response to: Re: deck installation by Mulepilot on Jul 20, 2005
- Re: deck installation by Doug on Jul 21, 2005
- Re: deck installation by Laszlo on Jul 21, 2005
