Re: petroglyph kayaker
Posted by George K on Jul 20, 2005
Dennis,
I don't know where the image is you're looking for but I would suggest rice paper for the image. You can run it through an inkjet printer by cutting an 8.5" x 11" piece and carefully glue it to a regular sheet of paper by running a small bead around the entire outside edge of the paper. You have to glue it down as it will bunch up going through the printer. Then cut as close to the image as you can, place it on the deck where you want it, lay the cloth over it and wet it out. The rice paper becomes invisible under the cloth. I'll attempt to post a pic and a link to a couple of pics. No promises.
ch18
In Response to: petroglyph kayaker by dennis tran on Jul 20, 2005
