Re: shear clamp bend
Posted by Howard on Jul 13, 2005
Not sure i understand the nature of the curve...can you post a picture?
assuming you you followed the directions, you will often get a bit of warping...particularly when you build during summer months... where you have wide variations in moisture in the air. by warping, i mean that the piece won't sit flat on a flat surface.
if it is simply warping, when the hull is stitched/tensioned, these problems typically just go away.
hs
In Response to: shear clamp bend by flip on Jul 13, 2005
- Re: shear clamp bend by Rich on Jul 14, 2005
