Re: metered pumps
Posted by Steve Miller on Jul 5, 2005
If you started with a 1/2 gallon of hardener and 1 gallon of resin then you should run out of both at the same time if the pumps are on. As pointed out above the hardener pump has a restrictor that only lets you do a 1/2 pump so by doing an equal number of pumps of each you automatically get the 2/1 ratio.
In Response to: Re: metered pumps by Donny on Jul 5, 2005
