Re: What to do, What to d
Posted by Howard on Jul 3, 2005
am not sure that i understand completely the question...so let me try this...
if i have to buy more product regardless of which way i want to go...MAS or System 3....i would invest in buying new material that matches the "newest" old material i have. (which sounds like MAS). you have already proven that the existing supply of MAS works...you just need to fill it out so you can complete the project.
i am not a fan of switching brands in the middle of a project even though i have been told it can safely be done....and i am not a fan of trying to mix 9 year old system 3 resin with new hardnener...i would want to make sure that the formulation has not changed during these 9 years.
at a minimum, if i were to consider trying to salvage the 9 year old system 3 resin, i would call the system three technical support number: http://www.systemthree.com/support.asp and get their view on if this is smart and i would certainly do a small test of the epoxy to ensure that it works as expected before committing to a large section.
hs
In Response to: What to do, What to do?? by RonC on Jul 3, 2005
