Re: 100 LBS
Posted by Charlie on Jun 29, 2005
The problem is more than front to rear trim. When you place 100 lb. on your deck you will be raising the center of gravity substantially. If you could get the weight below your deck you would have a much better chance of not capsizing. If you want to get a feel for the adventure get a 40 lb. bag of sand ($4-5)put it in a heavy trash bag to keep it dry and lash it to your deck. If you are able to paddle with it go and get a second bag and put it top of the first. I have a hunch you won't like the load. An outrigger would help make transporting this load much easier. Charlie
In Response to: 100 LBS by Susan on Jun 29, 2005
