Re: Pram ramblings & Qs
Posted by CLC on Jun 28, 2005
>>>>>> As a fix I am thinking of creating a new mast step that is roughly the same size as the factory step, albeit with the mast cutout in the middle versus on one side. Anyone see a problem with this?
That would work. Leaving the mast step alone will create more mast rake, which is not the end of the world. You can simply move the halyard attachment point further aft on the yard and the sail will maintain the same Center of Effort.
>>>>>>>>>>>>>>>>>> Otherwise the daggerboard seems to have alot of slop in it.
Ours does, too, in the shop, but on the water it jams to one side and doesn't move around.
I hate, HATE jammed daggerboards or masts.
In Response to: Pram ramblings & Qs by mullman on Jun 28, 2005
