Re: medium for fill coats
Posted by J.Schott on Jun 28, 2005
It was about 6 hours between fill coats. The delamination is between wet-out and fill coats. The interesting thing is that on the sides which already had been filled with 1 coat using the slow hardener, the next two using med flaked right off. the sides were prepped by sanding with 80 and 120 grit to insure adhesion. I'm baffled!
In Response to: medium for fill coats by LeeG on Jun 28, 2005
