paint and tinted epoxy
Posted by LeeG on Jun 28, 2005
I've put down a couple fill coats of white tinted epoxy then two thin coats of white paint. It lasts forever. It sounds like you want a hi-tech appearance. If you like carbon and don't mind the cost go ahead and put it on otherwise the field is totally open, you could get silk scarf and epoxy it over the glass,,nearly anything is possible. How about tinting the bottom panels dark purple then painting an Ibis with a thin white brush lines? Pure black coatings get stinking hot in the sun. That's my beef with them.
In Response to: Graphite then? by Rich on Jun 28, 2005
