Re: Switch epoxy brands?
Posted by Veto on Jun 19, 2005
I apparently was not clear enough about what I needed info on previously. My question is can I mix MAS resin with System 3 hardener or vise versa. I was not thinking that one brand of epoxy over a different brand could be incompat-ible. Chemically speaking, once the epoxy has set and cured out it should be nearly inert. Hope this clears things up and I get some useful info. Thanks, Veto.
In Response to: Re: Switch epoxy brands? by Veto on Jun 12, 2005
- Re: Switch epoxy brands? by CLC on Jun 19, 2005
