Re: Oxford shell building
Posted by Mislav on Jun 16, 2005
Dirk, you're the one with "L-s face away"?
Just to clear things a little, although this will work, I believe this is not how CLC designed it. The levelling legs should face forward, so that you can remove the unit sliding it in the aft direction, without the need for removing the bracket first. If you used wood screws instead of bolts (as found in CLC plans) you would probably destroy the thread after several screw/unscrew cycles.
I use bolts too. I'll post pictures as soon as it's finished.
In Response to: Re: Oxford shell building by Dirk on Jun 16, 2005
