Re: # of epoxy coats
Posted by George K on Jun 15, 2005
Paul,
You're right in thinking that two coats on the underside of the deck would be better than one if it was going to be exposed constantly to water or wear. However, if you have given it a good coat of epoxy right before installation if will be a sufficient moisture barrier. And if it's going to get a lot of wear that means you're spending too much time upside down with things not tied down in the compartments. Lastly, you ever tried to get a coat of epoxy on the underside of an installed deck? Ask Kurt Maurer just how easy that is!
George
In Response to: Re: # of epoxy coats by paul on Jun 15, 2005
- Re: # of epoxy coats by Pete on Jun 15, 2005
Re: # of epoxy coats by Mac on Jun 16, 2005
- Re: # of epoxy coats by RogerJ on Jun 16, 2005
- Re: # of epoxy coats by Mac on Jun 16, 2005
- Re: # of epoxy coats by RogerJ on Jun 17, 2005
- 303 protectant by Karl on Jun 17, 2005
- Re: 303 protectant by Mac on Jun 17, 2005
