Re: Mill Creek Hull Repai
Posted by Howard on Jun 14, 2005
use the same prep schedule as when you built the boat....usually 220 will give you a perfectly fine finish.
i would read the can for humidity and heat boundaries.
In Response to: Mill Creek Hull Repair by Matthew on Jun 14, 2005
- Re: Mill Creek Hull Repai by Skip on Jun 20, 2005
