Re: Measure by weight
Posted by David Bixby on Jun 10, 2005
!!!Caution!!!
I got into big trouble doing this.
I assumed the ratio by weight was the same as the ratio by volume. Your epoxy will not cure if you get the ratio wrong. At least mine didn't.
Find out the correct weight ratio and then try a small batch to see if it cures.
Also, if you are doing small batches, make sure you have a very accurate scale.
In Response to: Re: Measure by weight by Mislav on Jun 10, 2005
- Re: Measure by volume by Howard on Jun 10, 2005
Re: Measure by volume by Steve Miller on Jun 10, 2005
- Re: Measure by volume by Steve Miller on Jun 10, 2005
- Re: Measure by volume by Mike Delchambre on Jun 11, 2005
- Re: Measure by volume by Mike D on Jun 11, 2005
- Re: Measure by volume by Jack on Jun 13, 2005
