Re: Measure by weight
Posted by Mislav on Jun 10, 2005
I believe it is, but you'll need to know the specific gravity of both your resin and hardener. For example the epoxy I use mix in 1:2 weight ratio and 5:9 volume ratio. I use syringes for measuring.
In Response to: Measure by weight by Mike D on Jun 10, 2005
