Re: Foam Brushes
Posted by RogerJ on Jun 10, 2005
Mike, I have used the epoxy prep for the bristle/chip brushes, I also trim them a little shorter. This makes them a bit stiffer for spreaded thickened epoxy. The bristles will wick so if you apply too much epoxy at the base you may end uo with an un-usable brush. The foam brushes will soak up epoxy and sag, no perfect solutions Try both and choose what works best in a given situation. Ain't it great living in North American where we get such variety?
RogerJ
In Response to: Re: Foam Brushes by George K on Jun 10, 2005
