Re: RowWing again
Posted by Mislav on Jun 10, 2005
Nice to have you here Gary. Thanks for your tip. I'll make sure I follow your advice. Since noone responded before, I guess it should be allright to fix the outrigger at 41% LOA distance from stern - this is in the middle of my cockpit. I'll try to compare this position with my "guessed" waterline.
I also believe I found the best vertical placement. With footstrechers mounted in higher position and leveling legs in the lowest the heel cups are about 5mm above the hull, while my supposed waterline should be 85 mm above the heal cups and the same distance below the seat.
In Response to: Re: RowWing again by Gary Piantedosi on Jun 10, 2005
