Re: Light weight fillets?
Posted by paul on Jun 9, 2005
If leaving the wires in, how does one get such a small fillet ? or is that not possible? I believe the instructions call for the wire holes to be drilled 3/8" in from panel edges. That distance plus the arcing of the wire gives a fairly wide fillet to embed the wire. Can the hole placement off the edge be reduced? Too late for my current boat, but may be helpfull to other first-timers and for my next one. Thanks
In Response to: Re: Light weight fillets? by Laszlo on Jun 9, 2005
