Re: Not Ruined
Posted by Howard on Jun 8, 2005
well..i would say that that is fortunate...that its not sanding through the veneer
as i said...plain water, in my experience, does not produce a stain unless the water was coloured. stains due to water intrusion are areas that are left wet for a period of time and don't get a chance to dry out.
unfortunately...i am really having trouble interpreting your picture..and seeing where the problem is.
when you plain the shear clamp to attach the deck...is it not going to remove the area where you say you have some discolouration?
In Response to: Re: Not Ruined by Matt Croce on Jun 8, 2005
