Switch epoxy brands?
Posted by raul calzadilla on Jun 5, 2005
Project: MC 16.5 Hull was finished with MAS brand resin #718 and slow hardener #2072. Have about 2 qts. left which have been stored for maybe 2 yrs and still fluid, liquid condition.
Should I use this left over then switch to System Three (without mixing the uncured liquids, ofcourse)? I assume CLC sells the Syxtem Three now because of some advantage. In other words, does it matter if, once cured, epoxy brands are switched? tks
- Re: Switch epoxy brands? by CLC on Jun 5, 2005
Re: Switch epoxy brands? by Veto on Jun 12, 2005
- Re: Switch epoxy brands? by Veto on Jun 19, 2005
- Re: Switch epoxy brands? by CLC on Jun 19, 2005
