rotary cutter
Posted by LeeG on May 31, 2005
it's worth it. If you cut on 4mm plastic cloth the blade will last longer than cutting on hard surfaces.;$sessionid$GU1XFLIAACZCKP4SY5LRHOR50LD3UEPO?CATID=24988&PRODID=84622
In Response to: Re: When to add stern str by Mike D on May 30, 2005
