Re: Help! on Glassing Hul
Posted by Matt Croce on May 30, 2005
Thanks for the help; I'm going to finish sanding the rest of the hull (with 120 grit!) and then patch the area I sanded through and appply the final coat of epoxy.
I don't think the area at the front of the photo is unwetted glass, simply because there are a couple of other areas that look the same, and once I clean up the un-adhered portions, there is still glass underneath.
Thanks again, Matt
In Response to: Re: Help! on Glassing Hul by Howard on May 30, 2005
