denatured alcohol
Posted by Howard on May 29, 2005
i wipe down with denatured alcohol.
i also vacuum thoroughly.
i also use gloves in handling the boat prior to any glasswork to ensure i am not getting body oil/sweat on it.
as long as you are getting ready to glass...also keep in mind that you want the temperature in your work space staying level or decreasing during the process. you want to prevent outgassing which can mess up a perfect glass job.
hs
In Response to: Acetone by Robert N Pruden on May 26, 2005
