Re: outgassing
Posted by CLC on May 28, 2005
I agree with Lee; the whole outgassing thing is an issue to be aware of but not worthy of obsession, like surface contamination is. He mentions temp swings of 15 degrees which I think is a good number for what might cause trouble, at least if it happened in the space of two hours. If you anticipate a big shift, try to your epoxying when it's on the way down....
In Response to: outgassing by LeeG on May 28, 2005
