Re: Dynel Rub Strips
Posted by Matt Croce on May 27, 2005
Eh..ok...maybe I shouldn't hit "enter" right after typing the "subject line"...
Anyways, I have the glass and first layer of epoxy on the hull; I'm pretty happy with it, and I don't think I overdid the epoxy like I did on the inside.
Here's my question: I bought the rub strip kit from CLC; I'm not sure I want to completely use it the way they suggest. I'd like to incorporate the dynel into the hull a little more seamlessly, while I'm doing the glassing / epoxying of the hull. Does the Dynel wet out clear like the fiberglass does? Will it be ALMOST as abrasion resistant if I don't use the graphite / epoxy mix on it? (i.e. just use regular epoxy)
I'm hoping that I can just use the dynel strips on the bow and stern areas, and feather them in as I add the epoxy.
Any input?
Thanks Matt
In Response to: Dynel Rub Strips by Matt Croce on May 27, 2005
- Re: Dynel Rub Strips by terry on May 31, 2005
Re: Dynel Rub Strips by Karl on May 31, 2005
- Re: Dynel Rub Strips by Mac on May 31, 2005
- Brass Rub Strips by Karl on Jun 1, 2005
- Brass Pilot Holes by Mac on Jun 1, 2005
- Re: Brass Pilot Holes by paul on Jun 1, 2005
