Re: Bad taping fillet ima
Posted by Karl on May 27, 2005
Raul, You URL is getting a double http:// What you need to do when copying the link is delete the one that the forum outomatically supplies, and the link will work.
As far as the fillets are concerned, there certainly seems to be (more than) enough material behind the tape to fill the seam. Have you attempted to lift the tape with a heat gun? There may be a bunch of people her better qualified than me to chime in on this one.
I took th eliberty of fixing the link.
http://www.villagephotos.com/pubbrowse.asp?folder_id=1344122
In Response to: Re: Bad taping fillet ima by raul calzadilla on May 27, 2005
- fillets by mullman on May 27, 2005
- Re: fillets by raul calzadilla on May 27, 2005
- Re: fillets by Mac on May 27, 2005
- Re: Bad taping Thanks by raul calzadilla on May 27, 2005
