Re: epoxie temperature
Posted by Peter on May 27, 2005
Well I had a successful deck glassing. I was able to raise the temp in the garage from 50 to 62 degrees with the use of flood lights, space heater and I put a little fan in the doorway between the kitchen and the garage and just put a little more wood on the fire. ? about outgassing. Does this only happen on the first coat of epoxie where the wood can give of the gas? I would think that after the 1st coat the wood would be sealed and this would no longer be a problem. Anyway I'm glad I got it done and progress is being made.
Have a good day all, Peter
In Response to: Re: epoxie temperature by Mac on May 26, 2005
- outgassing by LeeG on May 28, 2005
- Re: outgassing by CLC on May 28, 2005
