Re: Wipe Down prior to Gl
Posted by Mac on May 26, 2005
Matt,
I've found - in cabinet work - that wiping down with any liquid will make the little "hairs" in the wood stand up - this may snag your cloth.
I would brush off the wood dry with a soft dust brush, vacuume the flor area, and smooth on your cloth. Take your time here. The cloth will eventually follow most of the curves, 'ceptin' at the very stern, witout any problems. I let it settle overnight and go over it once more prior to wet-out. (I actually use the same fine brush that I used for dusting to help smooth the cloth.)
You're getting to the exciting parts now.
Have fun....
Mac
In Response to: Wipe Down prior to Glass? by Matt Croce on May 26, 2005
- Re: Wipe Down prior to Gl by Laszlo on May 26, 2005
- Vacuuming helps too by Robert N Pruden on May 26, 2005
