Re: Wire Removal
Posted by Gert Walter on May 23, 2005
I removed the wires on two CLCs I built and won't do it again. I used epoxy tabs, so pulling out the wires was easy, but I think the color matchup is so poor that small copper specks would look much better. I spent quite abit of time matching the color of the okoume but to no avail in the end. Remember that whatever you put into the holes will change color with epoxy, then varnish. Good luck taking them out, but I will leave them in place in the future. gwalter
In Response to: Re: Wire Removal by Mac on May 23, 2005
