Re: UV Protection
Posted by LeeG on May 23, 2005
One of the things that's useful about the tests is that in order to have a cosmetically long lasting finish it helps to bury the glass under enough fill coats before the varnish goes on. If you sand to where the glass is barely being nicked you really can't make up for it by putting on more varnish.
http://www.oneoceankayaks.com/Epoxyhtm/epox12m.htm
In Response to: UV Protection by Tim M. on May 23, 2005
- Re: UV Protection by Tim M. on May 23, 2005
- Re: UV Protection by Dick R on May 23, 2005
- Re: UV Protection by LeeG on May 23, 2005
