Re: glass on ch17
Posted by Doug on May 22, 2005
The seam fillets and inside glass do a lot to stabilize the hull. When you invert it, do as Howard has suggested and support the hull on sawhorses whose surfaces are reasonably parallel with one another. Eyeball the boat for twist, and go to glassing.
Here's how I set my CH16 up.
In Response to: glass on ch17 by Eric on May 21, 2005
- Re: glass on ch17 by Doug on May 22, 2005
