Re: epoxy curetime to var
Posted by terry on May 17, 2005
I'm not sure if wet sanding the raw epoxy to 400 is the necessary, Mac. I just dry sand to 220 and save the fine grits for between coats. The 220 seems to give the finish coats a better grip on the cured, very hard epoxy.
But then again, I'm lazier than an Eskimo air conditioner salesman, so I tend to go with the absolute-minimum-effort-for-just-barely-good-enough-results approach.
70 F down here today. The Missus and me are gone paddlin' this weekend
terry
In Response to: Re: epoxy curetime to var by Mac on May 16, 2005
