Re: boat wear from heels
Posted by LeeG on May 16, 2005
same thing happened in a friends Coho. It had two layers of 4oz s-glass and it was worn into the wood. I put down a patch of 6oz eglass and then another patch of 5oz polypropelene which is almost as thick as dynel. If you see holes in the cockpit then you know someone has been using the kayak.
In Response to: Re: boat wear from heels by Howard on May 16, 2005
