Re: boat wear from heels
Posted by Howard on May 16, 2005
for preventing wear (vs creating a non-skid surface) another layer of 6 oz cloth where your heals will be is the way to go.
depending on your level of precision in determining where your heals will be...you will not need a lot of cloth/epoxy to do this.
simply sand the existing surface where you need the extra protection with 80/100 grit. then mask the area with duct tape. precut a rectangular piece of cloth slightly large than the masked area..and epoxy it in. while it is still green...cut the cloth along the duct tape edge and remove the excess cloth/tape. this will give your rub pads a nice professional look.
several fill coats...and you are ready to go.
hs
In Response to: Re: boat wear from heels by RogerJ on May 16, 2005
- Re: boat wear from heels by LeeG on May 16, 2005
