Re: Fine Line tape
Posted by Steve Miller on May 14, 2005
One more hint. If you are doing the paint over the edge on a yak then the round nose paint line is tough to tape the second, third, fourth time etc. Use something like a shot glass to make your curve. Tape over the ends then using a razor knife and your shot glass cut the curve into the tape on the sides. Be fussy to get it right. Its a detail that others will notice. For the following coats tape the sides first then make your new end curve tape off the boat on a poly cutting board. Carefully lift it up and put in place on the boat. Works slick.
In Response to: Re: Fine Line tape by Steve Miller on May 13, 2005
