temperature update
Posted by Mislav on May 9, 2005
Shop temp is now around 60 and falling. I found out that I could easily dent the tabs with razor blade using just a mild pressure, so I used this opportunity to clean some wires that got in touch with epoxy. Also tried hand sanding and it doesn't go off easily. So I decided to wait until tomorrow and to slightly hand sand the tabs after I remove stiches. Panel alignment is almost perfect and it would be shame to spoil it at this moment.
In Response to: temperature drop by Mislav on May 9, 2005
- Re: temperature update by CLC on May 9, 2005
- sounds reasonable by Karl on May 9, 2005
