Re: End Pours - CH17
Posted by Dick R on May 8, 2005
I suggest you put the decks on before doing end pours. Might as well make the whole end one big monolithic very strong block. And, you won't have to build dams. Don't mix filler with the epoxy. You do not care about the thickness; runny is fine and probably best. You are going to stand the boat on end and pour the epoxy in. Mix as normal, cure time as normal.
In Response to: Re: End Pours - CH17 by Howard on May 7, 2005
- Re: End Pours - CH17 by Howard on May 8, 2005
Re: End Pours - CH17 by CLC on May 8, 2005
- Not blind with camera by Lloyd Peterson on May 11, 2005
