Sealine Rudder
Posted by LeeG on May 5, 2005
Have you seen any ST with a Sealine Rudder? I wonder if the aft transom would provide a nice sturdy mounting that would enable a double blade to mount lower in the water than the high mounted Feathercraft double blade. The double seakayaks I've seen have deeper blades on double kayaks than the standard single blade on single kayaks.
In Response to: Re: Retractable rudder by CLC on May 5, 2005
