Re: MAS vs Silverpoint
Posted by Larry Roberts on May 1, 2005
I am still in the finishing stage ( since November) of a CLC 18 that has both MAS and SilverTip on the hull. I had almost a gallon of MAS left over from last years build of a 16 &17Lt. and being cheap I used this for every thing except the deck glass. I could't tell them apart. My MAS pumps are calibrated to give a smaller batch size than the SilverTip and I found I wasted a lot of the ST. I had no problem varnishing the deck but painting the sides & bottom was a pain. That was over MAS and had to do more with temp regulation in a cold climate with only limited heat in my work space.
In Response to: MAS vs Silverpoint by Woodie on Apr 30, 2005
