Re: sanding printed weave
Posted by James E. on May 1, 2005
Yea that seems like what Im dealing with. This being the first time I have sanded fiberglass its tough to tell how long it should take. Seems like I have gone through about 30 of the 80 grit discs and still have some spots with kind of a lemon like texture. But when I grab a sanding block and 100 grit paper I can smooth out the chines with a little elbow grease no sweat. It is kind of a translucent grey/white right? I worry about snading too far...How should I clean up the hull prior to the last fill coat? ...
Thanks so much for you help...and on Sunday no less!
In Response to: Re: sanding printed weave by CLC on May 1, 2005
- Re: sanding printed weave by Steve Miller on May 1, 2005
Re: sanding printed weave by Dick R on May 1, 2005
- Re: sanding printed weave by Gert Walter on May 1, 2005
- Re: sanding printed weave by RogerJ on May 2, 2005
- Re: sanding printed weave by James E on May 2, 2005
- Re: sanding printed weave by Dave Houser on May 2, 2005
